Anyone know what size it is? I did see on one site that it is m2x3. Can any one confirm before I trek to the the hardware store or Amazon.
Thanks,
Dave
Dell M.2 holddown screw
- stormsonweathers
- Contact:
Re: Dell M.2 holddown screw
What hardware are you using this screw on? Usually if Dell listed a specific m2 screw, in your case a m2x3, then that's what's needed. Laptops can sometimes be picky...
for the cost, i would recommend getting a general scew assortment like this:
https://www.amazon.com/gp/product/B07HC3LQYS
It's less than $7 USD and covers almost all and future needs for those types of screws.
If you're trying to tighten down a M.2 driver then these should help
https://www.amazon.com/2280ssd-Screws-P ... B08S7NV2B7
