black screen new gpu
i have a dell 5820 im trying to put a new gpu card in but i dont get a splash screen
- stormsonweathers
- Contact:
Re: black screen new gpu
Did you check the most common issues?
*check if the PCIE power cable is connected
*Make sure the card is slotted in?
*check the video cable between the monitor and card (did the cable work before?)
for reference, which card is it? There were some cards that's incompatible with some systems...
What power supply do you have and what graphics card did you put in the 5820?
