I recently purchased a refurbished T7910 Workstation and am interested to upgrade the RAM and am curious to know if there is a real difference in the workstation vs server RAM - is server RAM compatible or can I run with this configuration?
64GB (8x8GB) DDR4 PC4-2133P-R ECC Reg Server Memory RAM for Dell Precision T7910
I appreciate your feedback.
Dell Precision T7910 Workstation - Workstation vs Server RAM
- frankr2994
Re: Dell Precision T7910 Workstation - Workstation vs Server RAM
Registered ecc memory is spec. There really isn't a workstation/server difference. I'm guessing you're going off of eBay listing descriptions. Pc4-2133p registered ecc memory regardless of description will work fine in the 7910.
