Dell Precision T3610 My Gaming PC
- James_Bakster
- Member
Re: Dell Precision T3610 My Gaming PC
Corsair Corsair Node RGB
- James_Bakster
- Member
RTX 3060Ti with riser Asaka (AK-CBPE02-20B) in DELL T3610
- stormsonweathers
- Contact:
That looks awesome! What adapter did you use for your video card?
- James_Bakster
- Member
Asaka (AK-CBPE02-20B)stormsonweathers wrote: Mon Dec 18, 2023 11:01 pm That looks awesome! What adapter did you use for your video card?
- stormsonweathers
- Contact:
Thanks, gonna look into it!James_Bakster wrote: Tue Dec 19, 2023 3:56 amAsaka (AK-CBPE02-20B)stormsonweathers wrote: Mon Dec 18, 2023 11:01 pm That looks awesome! What adapter did you use for your video card?
- James_Bakster
- Member
Asus RTX 4070 Dual added.
- James_Bakster
- Member
Some updates for cooling.
- stormsonweathers
- Contact:
awesome work as usual! thanks for the updates!
I'm having fun upgrading my 3610 but I am having problem with power for the EVGA 3070 XC3 Ultra that I splurged on. I have already upgraded to the 685w power supply but I only have the two 6 pin connectors and a dual 6 to 8 adapter. I was about to give up on this project and put the GPU in a new build until I saw your build.
Could I power this GPU if I upgrade to the 5610 power distribution card. Would I then just use two 8 pin male to male cables? Please help this retro-building newbie.
- fredisherenthere
- Member
Win 10 Pro
Intel Xeon E5-2697 V2
256GB DDR3 1866MHZ PC3-14900
1300 Watt Power Supply
Stock CPU Cooler Modified with 3 Noctua 90mm fans +1 120mm for exhaust
Stock front fans replaced with 120mm Noctuas paired to each fan connector with 3 more 120mm Noctuas with zero fan errors
A19 BIOS Mod for NVME Boot
Dell Ultra 4x M.2 NVME Adapter Card 80G5N as Boot... Crucial CT1000P3SSD8 1TB
Samsung 870 EVO 2TB Storage
Gigabyte RTX 3070
Last edited by fredisherenthere on Fri Apr 12, 2024 5:51 am, edited 3 times in total.
